Elfsight widgets do not display on some MS Edge browsers. Is there a browser setting that needs to be adjusted?
Hi there and welcome to the Community, @user8924 ![]()
It seems that Edge is blocking the widget from loading due to the restriction settings. Could you please take 2 screenshots:
- a screenshot of the security settings
- a screenshot of the Dev Console in Edge on the page, where the widget is installed
If a strict mode is enabled in the settings, please try to disable it. It should resolve the issue:
Meanwhile, I’d like to assure you that we haven’t made any changes on our end, and our team believes this behavior occurred after the latest update to Edge.
