Elfsight LinkedIn widget doesnt appear in Edge
I have a regular LinkedIn feed running via Elfsight yet it never seems to appear in Edge, but display fine in Chrome and Firefox strangely!
I thought it might be a cache issue so have obv flushed the browser cache, removed the Wordpress caching plugin etc and it makes no difference!
Has anyone seen something similar to this?
Page affected is at Green Technology Solutions under the LinkedIn News section 3/4 of the way down the home page….
thanks in advance if anyone can help!
Hi there and welcome to the Community, @Chris_W_Balmer :waving_hand:
It seems that Edge is blocking the widget from loading due to the restriction settings. Could you please take 2 screenshots:
If a strict mode is enabled in the settings, please try to disable it. It should resolve the issue:
Meanwhile, I’d like to assure you that we haven’t made any changes on our end, and our team believes this behavior occurred after the latest update to Edge.
HI there
Removing STRICT mode cured it! Brilliant advice there @Max !!! Awesome
Many thanks mate
Oh, that’s awesome! You’re most welcome :wink:
