Why is my popup not showing on my website
Hi there, @Akua_Burns :wave:
As far as I see, you were trying to add the widget to these pages (1,2).
On the 1st page, there is no widget installation code, that’s why it doesn’t appear there.
On the 2nd page the widget is installed, but it didn’t appear because you set it to be shown on the specific pages. The thing is that, you should choose the specific pages if you added the widget to the website’s theme and want to display it on some pages only.
Google Sites platform doesn’t provide this option, and the widget is displayed only on the page where it’s installed. So, we’ve switched the Where to display Popup setting to All pages, and it’s displayed now:
I’d like to note that the widget isn’t floating on the page because of the iframes. Due to the peculiarities of the Google Sites platform, all floating elements are being converted into iframe format, which causes incorrect displaying. Unfortunately, there is no way to change this behavior, I am really sorry!
