View dashboard
Why is it that a little views dashboard appears when you hover over the comments app but Not when you hover over every app
Hi there, @user23472 :waving_hand:
The panel you’re seeing is the Elfsight information panel. It appears because you’re logged into your Elfsight account in the same browser where you’re viewing your site.
This means:
  • Only you can see it
  • Your website visitors will never see it
If you want to quickly confirm this, just open your website in an incognito/private window — the panel won’t be there.
Basically, the widget owners see this panel for all widgets from the account they are logged into.
Could you please send me a link to the page where this panel doesn’t appear with another widget? I’ll be happy to check things :slightly_smiling_face:
Hi Maximillian I assume…est perfumes Has 4 widgets but only one shows panel. This is not really a problem it just means another step for me to check the views on our backend
Got it, thanks for sharing!
Please let me check it with the devs. I’ll report back once I have their response :slightly_smiling_face:
Hi @user23472 :waving_hand:
Thanks so much for your patience while I looked into this!
I’ve checked with our dev team, and they confirmed that this is the expected behavior — the informational panel is not currently shown for floating widgets.
I hope this helps clear things up.
At the same time, I completely understand your use case, and I agree that having this panel available for all widget types would make the experience more convenient.
I’ve added this suggestion to our Wishlist on your behalf so our team can keep it in mind when considering future improvements: Display informational panel for floating widgets
