I am using the pop up widget! When I am trying to display the pop up on a specific page that doesn’t show up. That’s might be the case because the website is not in English and the pop up doesn’t recognize the URL language.
Things I did:
URL Encoded the specific path I wanted and insert it inside. Nothing happened.
URL Encoded the full URL still no results.
Does this popup read url if the language is not in English?
I’m happy to say that we do support other languages, and I’ll be happy to help!
We’ve checked your widget, and it seems the https protocol in your current link is also encoded, hence it doesn’t work. This link doesn’t get opened in a browser as well.
To fix the issue, please replace your current link with the following one: https://ouzounisdetectives.com/%cf%83%cf%87%ce%b5%cf%84%ce%b9%ce%ba%ce%b1-%ce%bc%ce%b5-%ce%b5%ce%bc%ce%b1%cf%82/
As it seems I have a problem loading the specific font-awesome right. While in your side works, when I try to load it in my website seems to fail. I have added inside the pop up the above html code because I wanted 4 buttons in the same row. I don’t believe that this is the problem, but I am almost certain that the problem here is that it’s hard to load font-awesome from an external source. As I read inside Console it says that :
I actually tried to load it with at least 10 different options I could think of like :
Changing the code (Multiple times)
Trying to load font-awesome through my website only.
Trying to load font-awesome through my web server with external css file.
Finding other cdn links that hosting files like that.
Changing type, as, rel, crossorigin, values inside link variable.
I apologize for the size of the reply but I needed to be exact and explain you everything,
Nick
Thanks a lot for such a detailed reply, Nick! Please don’t worry, the more details the better
I’m truly sorry that you have to face issues with our widget – I’ve already passed your request along to our dev team, and I do believe they will find a solution very soon.
As it seems my issue resolved. I can now see every pop up I have created correctly. I found that you need to specify some values when you are setting up a link attribute inside a HTML.
