Tracking Blog calls with Analytics
Hello Elfisght
How can we detect the opening of a single Blog item?
I see there is URL parameters set on opening the blog item.
But how can we “measure” this iin Analytics or Tag manager?
Is there a way using “customer specific JS?”
Thanks a lot
Piero
Hi @Piero_Biasi1 :waving_hand:
Our devs will try to come up with the code for tracking clicks on the posts. I’ll update you once the solution is ready :slightly_smiling_face:
Thanks a lot !!
Our devs came up with the Google Analytics code for you! Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
And then just add the rest of the script to the Custom JS field on the Settings tab of your widget’s settings:
	function sendEvent(config) {
		if (typeof ga !== 'undefined') {
			ga('send', 'event', {
				eventAction: config.action,
				eventLabel: config.label,
				event_label: config.label,
		return e.target && e.target.closest(selector);
		setTimeout(function () {
			sendEvent(config);
		}, 10);
		return true;
	return false;
document.addEventListener(
	'click',
	function (event) {
		const clickedContainer = event.target.closest(
			"[class*='card-container__CardContainer-sc']"
		if (clickedContainer) {
			const postTitle = clickedContainer.querySelector(
				'[class*="card-content__CardContentTitle-sc"]'
			)?.textContent;
				event,
				"[class*='card-container__CardContainer-sc']",
					action: 'click',
					category: 'Click Post',
					label: `Clicked Post: "${postTitle || ''}"`,
	true
Please let me know if it helps and if you have any other questions :slightly_smiling_face:
