How to track clicks in WhatsApp Chat using GA or GTM
I’m following this guys, max could you tidy the script and instructions up here - for everybody else?
Hi there @Nick_Templeton :wave:
In the previous thread, there were cases with the individual peculiarities, that’s why the codes didn’t work in some cases. I’ve moved your comment to a separate thread to avoid any confusion.
  1. For tracking clicks via Google Analytics, please add this part of the code to your website’s <head>:
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-ID"></script>
gtag('js', new Date());
gtag('config', 'UA-ID');
In the code above, you need to replace UA-ID with your actual website ID for Google Analytics. If you are using Google Analytics 4, you need to use G-ID instead of UA-ID (see screenshot). This article will help you find your ID - Find your Google tag ID.
    function sendEvent(config) {
            ga('send', 'event', {
                eventAction: config.action,
                eventLabel: config.label
                'event_category':  config.category,
                'event_label':  config.label
        return e.target && e.target.closest(selector)
        sendEvent(config);
    eappsDispatchAnalyticsEvent(event, '[class*="Bubble__BubbleComponent"]', {
        action: 'click',
        category: 'Open/Close WhatsApp Chat Widget',
        label: 'Open/Close WhatsApp Chat Widget'
    eappsDispatchAnalyticsEvent(event, "button[title='WhatsApp']", {
        action: 'click',
        category: 'Click WhatsAppChat',
        label: 'Click WhatsAppChat'
}, true);
  1. To track clicks via GTM, please follow these steps:
Adding the code
You should add this code to the Custom JS field on the Appearance tab of your widget’s settings:
function sendAnalyticsEvent(config) {
    const matchingItems = [
            selector: '[class*="Bubble__BubbleComponent"]',
            label: 'Open/Close Chat Widget'
            selector: '[class*="ChatButton__DefaultButtonComponent-sc"]',
            label: 'Click Start Chat Button'
    matchingItems.forEach((item) => {
        const match = event.target.closest(item.selector);
        if (match) {
            sendAnalyticsEvent({
                action: 'click',
                category: 'Elfsight Chat Widget',
                label: item.label
Creating triggers
  1. Click on New in your GTM account:
  1. Proceed to Trigger Configuration tab:
  1. Choose Custom Event from the list:
  1. Give the name to the event and save it after:
Test it out and let me know if it helped :slightly_smiling_face:
Is this instead of the GA TAG? or aditional code?
Thanks in advance!
Hi there @Alberto_Lung1 :wave:
If you mean tracking clicks via GTM, it is one of 2 possible options. Thus, you can track clicks either via Google Analytics or GTM :slightly_smiling_face:
The google analytics, I bealive it is : G-L92LM1S617 With ** ** or without?
Thanaks a lot
Without ** **. I’ve adjusted it in the code to make it more transparent :slightly_smiling_face:
Hi, i’v added the code as explained in step 1. But i see nothing events on a nalytics interface.
the site is: A Fáisca - Aulas Particulares
Am I missing anything ]
Hi @Alberto_Lung :wave:
Here, you should remove the asterisk (** **) and replace UA-ID with your actual ID as you’ve done in the 1st line of the code:
Check it out and let me know if it worked :slightly_smiling_face:
All working great!
