Analytics for Tools
I don’t see any analytics for each of my forms, is this currently available? It would be nice to see how many views,uniques, vs. interactions, vs. leads captured, etc.
Hi there @user12934 :wave:
Views statistics is available in your dashboard. Here is how you can find it:
Also, you can track clicks on the Submit button via Google Analytics and GTM.
Google Analytics:
Please add this part of the code to your website <head>:
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-ID "></script>
gtag('js', new Date());
gtag('config', 'UA-ID ');
In the code above, you need to replace UA-ID with your actual website ID for Google Analytics. If you are using Google Analytics 4, you need to use G-ID instead of UA-ID (see screenshot). This article will help you find your ID - Find your Google tag ID.
And then just add the rest of the script right before closing tag:
function sendEvent(config) {
    ga('send', 'event', {
      eventAction: config.action,
      eventLabel: config.label
      'event_category':  config.category,
      'event_label':  config.label
    return e.target && e.target.closest(selector);
  if (isHitClass(event, '[class*="ButtonBase__ButtonContainer"][aria-label="Submit"]')) {
    const requiredFields = document.querySelectorAll('[class*="FormLayout__Container-sc"] input[aria-required="true"]');
    const isFieldsFilled = [...requiredFields].every(field => field.value);
    if (isFieldsFilled) {
      sendEvent({
        action: 'click',
        category: 'Elfsight Form Submit Button',
        label: 'Submit Button Click'
}, true);
In order to see the statistics on clicks, please go to the **Reports** tab of your Google Analytics dashboard
Here you can choose the report type: Realtime Report or Reports Snapshot
Just in case, we have an article that describes how to work with each of them - Google Analytics 4 (GA4): Where to find my events.
GTM:
In this thread you’ll see how to track the number of delivered submissions.
Feel free to check it out and let me know how it worked :slightly_smiling_face:
Hey Max, does this work for squarespace sites?
Hi there, @jvmproperty :wave:
Yep, it should work for all platforms. If any questions or issues come up, please send me a link to your website. I’ll gladly look into this for you :slightly_smiling_face:
