I’d like to see basic analytics about how many times the timer was displayed on the landing page and how many clicks (button clicks) were done through the timer.
Hi there @Juliana_Joy and welcome aboard ![]()
The views statistics is available in your dashboard:
As for the clicks, you can track them using Google Analytics. Please add this part of the code to your website <head>:
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-ID"></script>
gtag('js', new Date());
gtag('config', 'UA-ID ');
In the code above, you need to replace UA-ID with your actual website ID for Google Analytics. If you are using Google Analytics 4, you need to use G-ID instead of UA-ID (see screenshot). This article will help you find your ID - Find your Google tag ID.
function eappsDispatchAnalyticsEvent(event, config) {
function sendEvent(config) {
ga('send', 'event', {
eventAction: config.action,
eventLabel: config.label
'event_label': config.label
return e.target && e.target.closest(selector)
sendEvent(config);
eappsDispatchAnalyticsEvent(event, '.eapps-countdown-timer-button', {
action: 'click',
category: 'Elfsight Countdown Timer',
label: 'Click to Countdown Timer button'
}, true);
Please let me know if it helps and if you have any other questions ![]()
