Track Button Clicks on Pop-Ups Compared to How Many Times They Are Viewed
Hi,
We have a few pop-ups running on our site and would like to track the ratio between the views these pop-ups receive and how many button clicks (submit) we get.
How can we implement this?
Hi @Sasha_Perry :wave:
Could you please share a link to the page where your popups are installed?
We have several pop-ups.
2 appear throughout the week on the homepage www.foundermade.com
Kind regards,
Sasha
Do I get it right that you’d like to track clicks on all widget’s elements (close button, submit button, clicks on the widget itself)?
We’d like to be able to track the close button, and the submit (/ register button on the alternate popup) yes!
Our devs have prepared a Google Analytics code for you. Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
    function sendEvent(config) {
        ga('send', 'event', {
          eventAction: config.action,
          eventLabel: config.label
          'event_category':  config.category,
          'event_label':  config.label
      return e.target && e.target.closest(selector)
      sendEvent(config);
    eappsDispatchAnalyticsEvent(event, '[class*="Popup__PopupContent-sc"]', {
      action: 'click',
      category: 'Popup',
      label: 'Click on Elfsight Popup'
    eappsDispatchAnalyticsEvent(event, '[class*="PopupCloseControl__PopupCloseControlContainer-sc"]', {
      action: 'click',
      category: 'Popup',
      label: 'Click on Elfsight Close Button Popup'
    eappsDispatchAnalyticsEvent(event, '[class*="ButtonBase__ButtonContainer-sc"]', {
      action: 'click',
      category: 'Popup',
      label: 'Click on Elfsight Subscribe Button Popup'
  }, true);
Please let me know if it helps and if you have any other questions :slightly_smiling_face:
Sorry for late reply!
Will this track all of our elfsight popups?
Thank you,
Also, is the second part of the script to still go in the header? I can’t see we have a in our header!
Yeah, this code will track clicks on all popups. The 2nd part of the script should be added to the website’s <body> and the 1st part of the code should be added to <head>.
Try it out and let me know if it worked :slightly_smiling_face:
Hi Max.
On Squarespace we can only add code to header and footer.
Sasha
Got you!
In this case, please try to add the 2nd part of the code to the footer and let me know if it worked :slightly_smiling_face:
