Team Showcase - see info pop-up
Hi, Can you tell me how i can reduce the width of the “see info” pop-up in the team showcase widget? I’m using the company structure template and I’d like the pop-up to be in the middle of the page but not the full width. Alternatively can the photo in the pop-up be reduced in size?
thanks!
Hi @Gina_Chong :wave:
I’ve checked your widget and the popup appears in the middle of the page and it’s not full width in the configurator:
Do I understand correctly that it looks different on your website? If it is, could you please send me a link to the page where your widget is installed?
In case the popup looks the same as in the screenshot and you just want to reduce its size, please let me know and I’ll share your request with the devs :slightly_smiling_face:
Hi,
Thanks Max! I’ll re-look at it today :slight_smile:
Cheers,
Gina
Gina Chong
Programme Administrator
E: gina@nzgda.com W: www.nzgda.com
Hey Max,
Yes if there is an option to make the pop-up smaller in size that would be great. No rush :slightly_smiling_face:
Thanks,
Gina
Hi there :wave:
You can change the size of the popup using a CSS code. Please add this code to the Custom CSS field on the Style tab of your widget’s settings and let me know if it helped :slightly_smiling_face:
.global-styles, [class*='Popup__PopupContent-sc'] {
  transform: scale(0.7) !important;
Thank you!!
Gina Chong
You are always welcome :wink:
In the meantime, we’d like to remind you about our customization challenge where you can win up to 12 free months. Don’t miss the chance to participate - March Challenge: Reveal Your Country’s Vibe and Win up to 12 Free Months!
