I found this CSS and tried it, but it took the images off the showcase itself, not just the popup when I click more info. How do I adjust?
Hi there @Sandy_Cunningham
Thank you for bringing this to our attention!
I’ve double-checked things and see that it works for all layouts, except for the 2nd one. I’ll discuss with the devs if there is a code that will work for each layout.
I’ll keep you posted
I am using the layout “teachers”.
Thanks!
Here is the adjusted version that should work for all layouts:
.global-styles,
.eapp-team-showcase-popup-item-photoContainer {
display: none;
.global-styles,
.eapp-team-showcase-popup-item-infoContainer {
width: 100% !important;
max-width: none !important;
.global-styles,
[class^="Popup__PopupContent"] {
width: 680px !important;
Try it out and let me know if you like what you see
That worked! Thanks so much.
Awesome!
In the meantime, we’d like to invite you to participate in our new challenge. This time, you should answer 3 simple questions about your favorite widget, and you’ll get a chance to win a 3-month extension to any subscription.
See the details and dive in - we are excited to get some insights from you
A post was split to a new topic: Make the popup image container in Team Showcase rectangle
