Store Locator - Question Re - Images - And bulk upload
I am using the Store locator - but i have a question.
When i used a CSV to bulk upload ‘stores’ it doesn’t pull in the Google data, that is available when I manually add stores by searching for it by name and address. It looks soo much nicer with an image. So i want to know if there is a way around this/solution to this?
Thanks
Richard
Hi there, @Richard_Kadri-Langfo :waving_hand:
We have a special aritcle explaining how to import locations from CSV - How to import locations from CSV to your Store Locator widget.
If you did everything right, please specify which data isn’t being pull from the CSV and send me your CSV file in a personal message.
For this, click on my profile image and click Message:
Thanks Max, this is very useful. One note of questions - tags. I have exported my current locations and can not see the tags i have added on the export. Therefore if i upload again, will this remove those?
Can you also clarify. If i upload a selection of locations - will it pull the location images from Google like it does when you enter them manually?
Ultimately on this last point I am asking - How do I get this: Url? https://service-widget-data-prod.sfo3.digitaloceanspaces.com/places-photos/78166a7f74793417a9065422684f8055.jpg
Unfortunately, tags and categories can’t be imported/exported to the CSV. I am really sorry!
We completely understand the importance of this feature and do have plans to look into this in one of the future updates. Please upvote this request to get notified about any changes - Bulk import for tags and categories.
For the image import, the images will show up in the widget if you add their URLs to your CSV file. To get an image URL, you’ll need to host the images on a service (for example, Google Drive, Imgur or any other platform) that allows public access to these images :slightly_smiling_face:
