When importing locations from CSV, add just location name and address and pull the other info automatically
Hi,
when i add a store manually using the button “ + Add Loaction “, i have nice result as the first part of the picture ( i think he find the store picture and store information on google )
on the second part of the picture , it’s when i add my shops with a csv file, i have this result not nice ( there is no picture and informations are missing )
how can i do to have a nice result as the first picture ( pictures, website, phones …informations found in google i think ) by using a csv file ?
Hi there and welcome to the Community, @user26426 :waving_hand:
To pull images along with the other info, you should follow the formatting ruled described in this article - How to import locations from CSV to your Store Locator widget - Elfsight Help Center.
If you’ve done this right, but the required info didn’t appear in the widget, please send me your csv file to my email address: m.salishchev@elfsight.com.
I’ll be happy to check things for you :slightly_smiling_face:
Hi Max
Thanks for your reply but I will try to explain my problem better.
When I add a store one by one manually, I just have to enter name store and city , and your widget find by itself the store with all informations and pictures.
I would like to do it with csv file but I don’t have all the informations and pictures as when I do it manually one by one
FLISS Sam
Co-fondateur
sam@bellemaispasque.com
+33767844994
+33486317816
Facebook
Instagram
TikTok
www.bellemaispasque.com
Ah, I see. Thanks for clarification!
I’ve moved your suggestion back to the Wishlist. If this request gets more votes, it might be considered in the future updates :slightly_smiling_face:
