Store Locator Default Map View on Mobile
Is it possible to change the default view to ‘Map View’ instead of ‘List View’ on the Store Locator Widget?
@Max Can you please add an option to select the default view on the mobile?
Hi there, @Boxon :wave:
We’ve added this code to the Custom JS field on the Settings tab of your widget’s setting to make the map view default on mobile:
function listener(selector, callback) {
  if (window.innerWidth > 480) {
    return;
  const firstTarget = document.querySelector(selector);
  if (firstTarget) {
    return callback(firstTarget);
  const observer = new MutationObserver((_, observer) => {
    const targetNode = document.querySelector(selector);
    if (targetNode) {
      observer.disconnect();
      callback(targetNode);
listener(
  '[class*="mobile-layout__Container-sc"] [class*="FloatingButton__FloatingButtonContainer-sc"] [class*="ButtonBase__ButtonContainer-sc"]',
  (button) => {
    requestAnimationFrame(() => {
      button.click();
Hey @Max,
I’m thinking this code wouldn’t fix this issue, View Map Button Issue - Mobile View ?
Best wishes,
mw
@iammasterweb Yep, this code helps display the map by default instead of the location list.
However, I’ve responded to you in this thread :slightly_smiling_face:
