Want to make a Map view in your Store Locator widget default on mobile devices? We’ve got a solution!
Just add the script below to the Custom JS field on the Settings tab of your widget’s settings and you’ll be fine ![]()
const openMapsButtonSelector = "[class*='mobile-layout__Container-sc'] [class*='FloatingButton__FloatingButtonContainer-sc'] button";
const LISTEN_TYPES = {
one: {
validate: (node) => !!node
all: {
validate: (node) => node?.length > 0
function listenStep(args) {
args.node = args.select(args.selector, args.root);
if (!args.validate(args.node)) {
args.step++;
if (args.step < args.limit)
setTimeout(() => {
listenStep(args);
}, args.delay);
else
args.reject();
else {
args.resolve(args.node);
async function asyncListenFor(selector, type = 'one', customArgs = {}) {
const args = {
root: document,
node: undefined,
selector,
delay: 100,
limit: 50,
step: 0,
select: LISTEN_TYPES[type].select,
validate: LISTEN_TYPES[type].validate,
reject: () => {},
...customArgs
if (type === 'one' || type === 'all') {
return new Promise((resolve) => {
listenStep({ ...args, resolve });
asyncListenFor(openMapsButtonSelector).then((openMapsButton) => {
openMapsButton.click();
Guys, was this solution helpful to you? Please let us know in the comments ![]()
