(Squarespace) How to create an Event Carousel
To create an Event Carousel, like this, you can follow these.
You can also use Event Calendar widget so you can customize Event easier without using complex code.
#1. First, find Event Page URL
In my example, it is: /events-1-2
#2. Next, edit page where you want to create a Event Carousel > Add a Code Block
#3. Use this code into Code Block. Remember to change Event Page URL
<div data-wm-plugin="collection-carousel"
  data-source="/events-1-2"
   data-loop="true"
></div>
#4. Install this Carousel Plugin
Plugin will give you some code to Code Injection Header/Footer
and Footer
#5. To hide Dots Pagination
You can use this extra code to Custom CSS.
div.collection-carousel-pagination {
    display: none !important;
#6. To make Carousel autoplay, you can use this attribute
data-autoplay="3000"
