To create an Portfolio Carousel, like this.
#1. First, find Portfolio Page URL
In my example, it is: /portfolio-1
#2. Next, edit page where you want to create a Portfolio Carousel > Add a Code Block
#3. Use this code into Code Block. Remember to change Portfolio Page URL
You can also use this Portfolio tool so you can add/customize Portfolio easier.
<div data-wm-plugin="collection-carousel"
data-source="/portfolio-1"
data-loop="true"
></div>
#4. Install this Carousel Plugin
Plugin will give you some code to Code Injection Header/Footer
and Footer
#5. To hide Dots Pagination
You can use this extra code to Custom CSS.
div.collection-carousel-pagination {
display: none !important;
#6. To make Carousel autoplay, you can use this attribute
data-autoplay="3000"
