I would like to change the sort order so my events are sorted alphabetically (A-Z) - is there a way to do this through custom CSS?
Hey there, @Info_at_BEST ![]()
Yep, it’s possible to achieve! Our devs will prepare a custom solution, and I’ll update you once it’s ready ![]()
Hi there, @Info_at_BEST ![]()
We’ve sorted your events alphabetically. Please check your widget and let me know if it’s fine now ![]()
If you add new events, the alphabetical sorting will stop working. To make it work again, please reach out to us again. Our devs will be happy to help!
I frequently add events so if there is a way for me to do it in the future please let me know. Appreciate the support
Unfortunately, this behavior can be set on our end only. So, once you add new events, feel free to let us know and the devs will gladly help you ![]()
Hi Max - I added new events - can the team help resort them to be alphabetical again? Thank you so much! About BEST
Sure! I’ll get back to you once the devs complete the alphabetical sorting ![]()
Done! Please check the widget in the editor and if everything is fine, click on the Publish button to make the live ![]()
Hi Max, we need to sort the events again. Would you please work your magic so that the events sort alphabetically. Thanks!
Sure, I’ve passed it on to the devs and will update you once it’s done ![]()
We’ve updated the event sorting! Please check your widget in the editor and if everything is fine, click on the Publish button to make changes live ![]()
Sure, I’ve passed it on to the devs and will let you know once the sorting is completed ![]()
The sorting has been implemented, you can check the result in the widget configurator. To make changes live, just click on the Publish button in the top right corner ![]()
