Customize event order
I have an event that is on the same day. One event ends at 6pm, and the other ends at 5:30pm. They both start at the same time. I’d like the one that ends first to be listed first. Is there a way to do that?
Hi there, @Erin_Horswill :waving_hand:
Could you please specify the name of your Event Calendar widget and the names of the events you’d like to swap? I’ll be happy to check if anything can be done :slightly_smiling_face:
Thank you. It is our 2026-2027 Drama Classes. I’d like Drama I listed before Drama II.
Thanks! I’ve passed it on to the devs and I’ll update you once I have their response :slightly_smiling_face:
Hi @Erin_Horswill :waving_hand:
Our devs adjusted the order of events in your widget!
If you have any questions left or any assistance is needed, we’ll be happy to help :wink:
