Is it possible in the RSS feed widget to open the full feed by default rather than having to click on the “read more” button to expand the post.
Website still under construction ATM so I cannot share link
Many Thanks
Richard
Many Thanks
Richard
Greetings @Richard_Neep ![]()
Sure! This code should do the trick - Remove Read More and display full text.
Give it a try and let me know if it helped ![]()
Thanks so much Max - Brilliant, works a treat!!
You are always welcome!
By the way, we’d like to invite you to participate in our latest challenge. Just answer 3 simple questions about your favorite widget and you could win 3-month extension to any of your subscriptions.
Your feedback means a lot to us and really helps steer us right. So, if you could take a moment to share your insights, we’d be super thankful ![]()
Hi,
You very kindly supplied some custom CSS to enable my RSS feed widget to open automatically.
It has worked fine for the last month but now doesn’t
The feed is correct and opens in other apps
Many thanks
Richard
Hi there @Richard_Neep ![]()
Ah, I am so sorry about it!
I’ll discuss it with the devs and will report back tomorrow ![]()
We’ve adjusted the code:
.global-styles,
[id*="eapps-rss-feed"]
[class*="SimpleShortener__Outer-sc"] {
max-height: none;
.global-styles,
[class*="Text__Container"] >
[class*="Text__Control"] {
display: none;
Please check your widget and let me know if it’s fine now ![]()
Thanks so much
All working well now
Thanks once again for your excellent customer support!
Best regards
Richard
No problem at all ![]()
In the meantime, I’d like to remind you about our Birthday Challenge, where you can win a 1-year extension to your subscription. Check the details and dive in - Birthday Contest: 12 Winners, 12 Free Years with Elfsight! ![]()
