a widget to have a réservation
Welcome to the Elfsight community, @user2354, and thanks a lot for your suggestion!
Do you think our Form Builder widget could help you? It has a Reservation Form template that seems like a possible solution for your use case, you can check it out here: Reservation Form Templates - Create Online Reservation Forms
Let me know if it helped
