been using the contact form for a while now, and i have customized the contact form to my needs (e.g. changed the labels to dutch). Whenever i receive an contact form, and want to reply tot the sender it changes to wordpress@domain.nl. I looked up all the field id’s and i have set the right field ID in the ’ reply-to’. e-mailsettings. In my case it is [wat-is-je-mailadres?]. But as i said, it doesn’t work.
So, i’ve been testing with different id’s and also try to see if it works when i put in the message body. The field is is shown, not the resulting field content.
So; then i tried to see if it works when i make a new contactform, and make everyting default. That works! So it seems that whenever you try to change the label name, the ’ reply-to’. stops working.
Could you please send me a link to the page where the widget is installed (if it’s not installed yet, please specify the widget ID)? I’ll gladly look into this for you
btw; when i keep the contact form in its original state (so no labels changed) the contact form works flawlessly. So; it must have something to do with the changing of the id’s.
Oh, I see, you’re using our WP standalone plugin, which looks and works differently. I have to say that this forum is dedicated to Elfsight cloud apps, thus we can assist with only cloud apps-related questions here.
I advise you to ask your question via our CodeCanyon form, our team will try their best to provide the answers there
