Questions about a Display Error (Event Calendar)
Hello Helga,
I noticed a display error in the “Event Calendar”. Since the error has been around for a while now, it seems to only affect me.
That’s why I asked if the developers could take a look at it? What the error looks like can be seen in the two attached screenshots. “Image01” is from 8 months ago. “Image02” is from this week.
The error is not particularly serious, but a little annoying. Maybe you already know the error?
In any case, I would like to thank you very much for the good service and the many offers on Elfsight! Keep it up!
If I should contact someone else about this error, please let me know briefly.
Best regards, Gam!
Hi there, @Gam :wave:
Please let me step in for Helga!
We’ve fixed the issue by adding this code to the Custom CSS field on the Appearance tab of your widget’s settings:
.eapp-events-calendar-grid-item-imageContainer {
  max-width: unset !important;
Check it out and let me know if it’s fine on your end now :slightly_smiling_face:
thank you for your message.
I have now looked at your solution with different browsers and also on mobile devices.
Now everything looks the same again, everywhere, on every device and across every browser. Thank you for that. I will keep the code in the custom CSS exactly as it is. :slightly_smiling_face:
I am very happy with it! :+1:
Thanks again for the very quick support!
My “ticket” has been resolved.
Best regards!
Amazing, you’re always welcome!
In the meantime, we’d be so grateful if you could look through the Event Calendar Wishlist category and upvote the ideas you like most.
Your feedback is really important for setting the right priorities :wink:
