- Issue description:
Does anyone know a css code i can paste in to display the full image size as the thumbnail? the grid view is currently cutting off the event image.
Hello @Anthony63! We are so happy that you’ve decided to join us! Welcome to Community
We’ll be happy to check everything for you!
I’ve forwarded your request to our devs and, hopefully, they’ll come up with a proper solution really soon ![]()
Please do not worry, I’ll keep you updated ![]()
@Anthony63 We’ve checked your website from different devices and event images look fine:
Could you please provide me with a screenshot of what you see?
What you’re seeing is the masonry view. The issue is when I select grid view.
I would like the thumbnails to display like masonry view but when using grid view.
Masonry view I don’t like how it’s staggered in some spots and sometimes the dates are out of order. Seems to be a glitch.
Hi @Anthony63 ,
This CSS code should do the trick. Let me know if it works.
.eapp-events-calendar-grid-item-imageContainer {
padding-top: 182%;
.eapp-events-calendar-grid-item-imageContainer img {
object-fit: cover;
This worked !! Thank you : )
