When using both the Pricing Plan widget and Calculator on the same webpage, the selected pricing plan should auto-select the chosen pricing plan in the calculator that is used to generate a more exact quote based on the additional options chosen.
Hi there, @Sonja_Kirschner ![]()
I see that you have only 3 plans in your Pricing Table widget and the Calculator offers 6 plan options.
Are you going to add more options to your Pricing Table widget, or you’d like only 3 options to be automatically chosen in the calculator?
