Possible to add another currency symbol on the calculator?
Enjoying the calculator so far, but it’d be great to add other currency symbol apart from dollar sign? E.g. £
Greetings @Chow_Brian :wave:
Glad to tell you that you can easily change the currency right in the settings. Just choose the required calculation, click on the Format and set the Currency:
Let me know if it helped or if you have any further questions :wink:
Bril! Thanks for the solution. <£
It’s no bother :wink:
