Hi guys
Calculator is great but has only few currencies. Please add CHF or possible to use any currencies or we can’t use it.
Hi guys
Hey there and welcome aboard @user5513 ![]()
Sure, our devs will gladly add CHF to the Calculator app. I’ll keep you updated ![]()
In case, you’d like to add more currencies to the widget, please specify which ones you need most. We’ll be happy to add them for you as well!
Hi there @user5513 ![]()
While our devs are working on the implementation of the most popular currencies, here is the workaround you can use:
Please check it and let me know if it helped ![]()
thank you for your workaround. I see, that you already fixed our calculator! Top notch Service! ![]()
Great, thanks a million for your fantastic feedback ![]()
If any further questions come up, we’ll be more than happy to help!
