Add Currency Toggle
Like Price Tables, it would be helpful to have currency toggles.
Hi @Support16 :wave:
Thanks for the idea! We’ll keep it in mind and see what others think about it :slightly_smiling_face:
I would be glad if you included Multi multi-currency selector
Hi there and welcome to the Community, @Alfred_Atsaba :waving_hand:
Glad to say that we already have a similar idea on the Wishlist, I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
As a workaround, you can create a dropdown for the currency selections. Then all the other fields and calculations should have a separate version for each currency, which should be displayed using the conditional logic feature.
Here is a video screencast showing an example of this setup:
