Pop-up on the right side
Hy, I am looking for a pop up, in which you can put 6 headlines with links, in front of each 1 own icon
Hi @Sybille_Schleicher_K and welcome aboard :wave:
Sure thing, we’ll be happy to advise! Could you just describe your use case in more detail? What icons would you like to use? A screenshot of what you’d like to achieve would be really helpful :pray:
Hy Max,
this is how it should look and be linkable
I’ll discuss it with our devs and get back to you a bit later :slightly_smiling_face:
super Thank you
Sybille
Happy to tell you that it’s possible to customize Popup widget this way.
You just need to add Image, Text and Separator blocks:
This way, you can add links to your text:
Please let me know if this explains things or if any questions come up :wink:
This looks good. Which pop up template do I choose to make this work?
You can choose New Collection Template
ok, I’ll try it and get back to you tomorrow
Thank you
You are always welcome :wink:
Hallo,
I tested the pop up.
The text is on the left, the image on the right (squashed). The picture should be above the text.
Greetings
Sybille
I’ve changed image layout and scale, so that it looked the way you like, and saved changes in your widget:
Please check it and let me know if you like what you see :slightly_smiling_face:
Great! Thank you.
One more question about the popup. Can I set it up so that it only opens automatically on the start page, on the other pages only when you click on the button on the right side of the screen?
Another question about the pop-up. The pop-up should only open once automatically on the home page. Otherwise only when you click on the button, is that possible?
Do I understand you correctly that you want the popup to be displayed only when the visitors visit your website for the first time?
Hallo Max,
no not really. I want the popup to open when entering the webpage. If you then clicked away the popup, it should only open when you click on the button. So if you go to a subpage, only the button should be visible, which you can then click if necessary.
Sybille
I got you!
Unfortunately, there is no option to customize the widget this way. I am sorry :pensive:
The only workaround is to make widget copies and use them with different triggers.
Please let me know if this explains things or if you have any other questions.
ok.
Is there a way to show only the button and only when you click it the popup opens?
Sure, you just need to choose On Click trigger in the Triggers section on the Settings tab and add HTML Element ID of the button that should trigger the popup:
