Place of the widget on my site
  • Issue description:translation widget
  • Link to the page with the widget in question: veronicas art.nl
At present, the widget is placed at the bottom of each page. Is it possible to replace it to the right-hand top of each page? If so, how to do it ?
@Ron_van_Vugt : It sounds like you are using the ’Inline’ embed type and placed the Elfsight code at the bottom of your page. The inline method places the widget wherever you insert the code. I think a better match for your needs might be the ‘floating’ embed.
In the widget edit mode, select ‘Floating’ and then select the text next to the Position label (it defaults to Top Right). Doing so reveals a positioning sub-menu that allows you to fine-tune the vertical and horizontal positioning with sliders. If the value you need exceeds the value of the slider, you can simply click the pixel (px) text and type any number required.
Hey there, @Ron_van_Vugt :waving_hand:
Bob is absolutely right! You just need to change the layout to Floating on the Settings tab and choose the Top Right position>
Let us know if it worked for you or if any further assistance is needed :wink:
@Bob_Wilson, many thanks for your quick help!
