Hello,
I installed the widget on my site yesterday. I already have three reviews, but nothing is visible yet. Is there a minimum number of reviews I need for them to be displayed?
Thank you for your help.
Hi there, @RyKeR_s3D ![]()
I’ve checked your widget and see that the reviews are displayed now ![]()
The new reviews don’t appear in the widget right away because of the cache. The cache time for our Reviews apps is 72 hours.
If it’s been more than 72 hours and the new posts still didn’t show up, please let me know and I’ll gladly look into this for you!
Merci beaucoup pour l’information, en effet, cela fonctionne actuellement, j’ai encore une petite question, je n’ai plus laisser visible l’adresse sur ma fiche google, est ce que cela a ou aura un impact sur les futurs avis?
Thank you very much for the information, indeed, it currently works, I still have a small question, I no longer leave the address visible on my Google profile, does this have or will have an impact on future reviews?
Non, cela n’affectera pas les performances du widget et les nouveaux avis seront ajoutés au widget ![]()
No, this won’t affect the widget’s performance and the new reviews will be pulled to the widget ![]()
