NetworkError when attempting to fetch resource
Redirekt does not work from PoPUp
I get there errors since today
Quellübergreifende (Cross-Origin) Anfrage blockiert: Die Gleiche-Quelle-Regel verbietet das Lesen der externen Ressource auf https://data.elfsight.com/public/resources/form-submissions/. (Grund: CORS-Kopfzeile ‘Access-Control-Allow-Origin’ fehlt). Statuscode: 429.
Form submit error: TypeError: NetworkError when attempting to fetch resource. app-BjmvLca-.js:125:13074
jz https://universe-static.elfsightcdn.com/app-releases/popup/stable/v2.31.12/1d98479bb8f20176288ab5b2c3c354df8568d631/preview/assets/app-BjmvLca-.js:125
Hi there, @Ulrike_Braun :wave:
Could you please send me a link to the page where your widget is installed?
Guten Tag,
sure - first option
https://www.gaeb-online.de/gaeb-bestellung.html
Mit freundlichen Grüßen
gaeb-online, Ulrike Braun
Kraichgaustraße 15
D 75045 Walzbachtal
Schulungen
https://www.gaeb-online.de/gaeb-schulung.html
Hilfe
https://www.gaeb-online.de/hilfe2014/index.html
Produktübersicht
https://www.gaeb-online.de/gaeb-ueber.html
Neues
https://blog.gaeb-online.de
Datenschutzhinweise
https://www.gaeb-online.de/gaeb_data.html
Impressum
https://www.gaeb-online.de/gaeb_impr.html
Lizenzvereinbarungen
https://www.gaeb-online.de/gaeb_agb.html
I’ve checked your website and everything worked fine on my end.
Could you please test it incognito mode and let me know how it worked?
Guten Tag,
its works now, but dod not on the weekend. Did you see the errors vom Firebug-Console
Hmm, I haven’t seen any errors in the console. Last week, one more customer faced a similar issue. The forms couldn’t be sent because of the Adblocker extension in his browser. Once it was disabled, the widget worked fine.
Did you previously use similar extensions in your browser?
Guten Tag,
no add-Ons, 3 Machines one on macOS - same issue yesterday.
Error was Statuscode: 429
and
Got it, thanks!
It’s hard to say what caused this issue, however, I am happy to hear that everything is fine now :slightly_smiling_face:
If the issue occurs again, please let me know. I’ll gladly look into this for you!
