Good morning, I need to track clicks on each marker in my store locator. Is there a way to do this? If so, could you show me how? Thank you
Hi there, @Pracal_Srl ![]()
Our devs will try to create a code for tracking clicks via Google Analytics. I’ll report back once the solution is ready ![]()
I am happy to inform you that our developers have prepared a Google Analytics code for you. Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
And this script was placed in the Custom JS field on the Settings tab of your widget’s settings:
const locations = {
"b5050aff-e7a4-4b01-bd47-f15480e5bfc5": {
"name": "Sescotec Srl",
"address": "Via P. Solinas, 11, 07043 Bonnanaro SS, Italia"
"a1c4cfa1-2860-478b-a58a-f923bd1fe69b": {
"name": "Radu Serramenti",
"address": "Via Piossasco, 78, 10090 Bruino TO, Italia"
"81e4f2fc-1a00-4ba7-a3a9-8a987a457ddf": {
"name": "Tech International Srl",
"address": "Via Boschetto, 9, 23880 Casatenovo LC, Italia"
"a356028d-34e3-4af1-9888-85074be0139d": {
"name": "Non Conventional House",
"address": "Viale Giovanni Capreoli, 105, 73037 Poggiardo LE, Italia"
"21d97024-5d9c-4436-80cf-a4d6284e74d2": {
"name": "CS SISTEMI",
"address": "Via Po, 3/A, 10090 Castiglione Torinese TO, Italia"
"fde334ad-7142-4c0c-b718-bd8443202e54": {
"name": "Dolermo Avvolgibili s.r.l",
"address": "Via Antonio Cecchi, 34, 16129 Genova GE, Italia"
"82eeb593-b787-4082-948d-8f182446d9fc": {
"name": "TECNODOOR porte blindate",
"address": "Via dei Colli, 3, 31051 La Bella-ligonto TV, Italia"
"9c71ca4d-2211-45b2-b558-fa3f95c8f548": {
"name": "Albaceramiche Srl",
"address": "Via Oriago, 115, 30174 Venezia VE, Italia"
"11a51da0-40e6-4cad-aefd-1b0a683c41fc": {
"name": "Bosetti Serramenti",
"address": "Via Madonnina, 11, 25018 Montichiari BS, Italia"
"fe8626d7-4ecb-41f6-9a1f-1a3282d3e085": {
"name": "Tende da sole Lucatelli Luigi",
"address": "Via Augusto Dulceri, 48, 00176 Roma RM, Italia"
function sendEvent(config) {
ga("send", "event", {
eventAction: config.action,
eventName: config.name,
eventAddress: config.address,
gtag("event", config.action, {
event_name: config.name,
event_address: config.address,
const isHit = e.target && e.target.closest(selector);
return isHit;
sendEvent(config);
document.addEventListener(
"click",
function (event) {
const marker = event.target.closest('.maplibregl-marker');
if (!marker) {
return;
const locationIdClass = marker.classList[0];
const locationId = locationIdClass.replace('elfsight_map_1_', '');
const {name, address} = locations[locationId];
event,
'.maplibregl-marker',
action: "marker-click",
name,
address,
true
This article explains where you can find info about clicks: Tracking Events in Google Analytics 4 - Elfsight Help Center
Check it out and let me know if it worked ![]()
