Statistics on number of clicks per store/dealer
Hi, to impress our dealers with usage and clicks that we generate for them via this tool, we would like the option to see (only in the backend) the number of clicks (over time as well) per store/dealer found via our dealerportal.
Hi there and welcome to the Community, @user30992 :waving_hand:
Would you like to track clicks on the location markers and the corresponding locations in the side panel separately, or would you prefer to count them together as one?
For example, if you click on the Lumar Verhuur marker and then click on Lumar Verhuur in the side panel, should both clicks be counted as just 2 clicks on Lumar Verhuur? Or should they be identified as 1 click on Lumar Verhuur marker and 1 click on Lumar Verhuur in the side panel?
Hi Max, thank you for getting back! Well, if you can identy the 2 seperately, that would be awewome.
Would it also be possible to, separately, see the amount of clicks to their website, via the URL provided in their card?
Thx, Dennis
Got it, thanks!
I am not sure if it’s feasible, but I’ll discuss it with the devs and will update you once I have their response :slightly_smiling_face:
Our devs can create a custom code for tracking clicks through the Google Analytics. Would you like to proceed this way?
If so, could you please specify the name of your Store Locator widget, where you’d like to track clicks?
I think that would be great! i created 2 locators, they are the same, only the language is different. So the results of the 2 can be combined in one pool of data
Got it, thanks!
I’ve passed it on to the devs and will update you once the solution is ready :wink:
Hi there, @user30992 :waving_hand:
Unfortunately, there is no way to track clicks on markers, but our devs created a code for side panel and website URLs clicks.
Please add this part of the code to your website <head>:
<script async src="https://www.googletagmanager.com/gtag/js?id=*G-ID"></script>
gtag('js', new Date());
gtag('config', 'G-ID');
And then just add the rest of the script to the Custom JS field on the Settings tab of your widget’s settings
function sendEvent(label, locationName) {
  const config = {
    action: 'click',
    category: 'Store Locator',
    label,
    locationName
  if (typeof ga !== 'undefined') {
    ga('send', 'event', {
      eventAction: config.action,
      eventLocation: config.locationName,
      eventLabel: config.label
      event_location: config.locationName,
      event_label: config.label
document.addEventListener('click', ({ target }) => {
  if (!target) {
    return;
  const isWebSite = target.closest(
    '[class*="location-card__Container-sc"] [class*="contacts-item__UnderlineWrapper-sc"][href*="http"]'
  if (isWebSite) {
    const locationName = document.querySelector('[class*="multi-column-layout__Column-sc"] [class*="business-info__Block-sc"] div');
    sendEvent(`Click to WebSite: ${target.textContent}.`, locationName.textContent);
  const sideBarLocation = target.closest('.es-location-preview-image');
  if (sideBarLocation) {
    const locationName = sideBarLocation.querySelector('.es-location-preview-title');
    sendEvent(`Click to sidebar location`, locationName.textContent);
This article explains where you can find the click stats -Google Analytics 4 (GA4): Where to find my events - Elfsight Help Center
Please let me know if it helps and if you have any other questions :slightly_smiling_face:
