Click Tracker
It would be great to see how many times the button has been clicked on
Welcome to the Community, @Aleksey_Volchek :waving_hand:
I agree that it would be awesome to have a click tracker right in the dashboard. If this idea gets more votes, we’ll try to think it over in the future.
As for now, you can track clicks on the button using the Google Analytics code. Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
And then just add the rest of the script to the Custom JS field on the Settings tab of your widget’s settings:
	function sendEvent(config) {
		if (typeof ga !== 'undefined') {
			ga('send', 'event', {
				eventAction: config.action,
				eventLabel: config.label,
				event_label: config.label,
		return e.target && e.target.closest(selector);
		sendEvent(config);
document.addEventListener(
	'click',
	function (event) {
			event,
			'[class*="Block__BaseBlock-sc"] > button[type="button"]',
				action: 'click',
				category: 'Elfsight Banner',
				label: 'Click to Banner Button',
	true
This article explains where you can find the info about clicks - Google Analytics 4 (GA4): Where to find my events - Elfsight Help Center.
Try it out and let us know if it helped :slightly_smiling_face:
