Track clicks using Google Analytics
There lacks analytics from elfsight
Hi there and welcome to the Community, @Dan1 :waving_hand:
Thank you for the feedback!
I agree that it would be amazing to have a Google Analytics integration be available right in the widget. We’ll try to consider this opportunity, especially if more users support this idea.
In the meantime, we’ll be happy to provide you with a custom solution. Could you just share the name of the Announcement Bar widget, where you’d like to use the code and the widget elements you’d like to track?
Im so happy some of the widgets like the all in one reviews got this update!!!
While the GA integration isn’t built in the Announcement Bar yet, our devs will gladly create a custom solution for you.
