The List View for the Calendar APP does not show the dates of past events.
Will you find a way to add this?
Hi @user130!
You know, it looks like a bug, I’m very sorry about it! I’ve already forwarded it to our devs so that they fix it for you. I’ll keep you updated here ![]()
Thanks a lot for your help!
@user130 thanks a lot for your patience!
The issue is fixed, so the Past events go with the date as well ![]()
Could you please check things on your end?
My Calendar is not showing past events ??? any Reason why? We need this for future reference for staff and followers.
Jennifer
Hi there @SDFRW_Website ![]()
To display past events, you need to enable this option in the Past Events section on the Layout tab:
