Light-Dark mode widget
Hello, I was hoping if you guys could make a light-dark mode widget for Wix websites as I would like to let me users click it to change the website theme to light or dark depending on their preference and to save the preference using browser cookies so when they come back to the site it will remember what preference they had. Thanks!
Hi @Feliks thanks a lot for a great suggestion!
I love the idea of saving the preferences for a user, and we even have such a widget in mind: Dark Mode widget - add a stats widget to your website (2024)
At the moment we have to consider the most popular requests first, so feel free to vote for all the ideas you find interesting to bump them up :slight_smile:
Thanks a lot for your help and welcome to the Elfsight Community! :tada:
Dark Mode widget
make it work on the js as well, i mean lot dark mode widgets don’t work on my e-commerce site, it either gets hidden behind the website/ui or it doesn’t completely work like: it doesn’t work on products - as its seperately loaded along or after site. 2) make it auto work & detect preference.
Do you use Wix for your website because that is what I use but every dark mode widgets I try to use don’t work?
It was actually ecwid, now I’ve shifted to woocomere by WordPress
Cool, I never heard of that platform before.
Try darkmode.js if it allows to put a code
It does allow me to put code but it doesn’t work.
An html you can embed that allows you to toggle your site between a light mode and a dark mode.
Thanks!
Great idea, @ClickFuel, thanks a lot for sharing and for joining the community! :slight_smile:
We have a Dark Mode widget in our Coming Soon project, so the chances are we’ll take it under consideration :slight_smile:
At the moment we’re working on building other widgets so I cannot set an ETA for this one, unfortunately, but I’ll keep you updated in this thread.
Many thanks for your help!
Awesome can’t wait to see the dark mode widget!
You allready have that in the dashboard with cloud and sun, with moon and stars.
@Alexandros_Zeppos Do I understand it correctly that you want to add dark or light mode to the configurator of all our apps?
No not correct. Maybe you can do that. I was referring to the website appearance if that is possible
Στις Δευ 25 Σεπ 2023, 16:13 ο χρήστης Max via Elfsight Community <notifications@elfsight.discoursemail.com> έγραψε:
I am wrong. It would not have paid option
Στις Δευ 25 Σεπ 2023, 16:15 ο χρήστης Alexandros Zeppos <alexandroszeppos7@gmail.com> έγραψε:
Maybe if in free edition you could add elfsight brand on the screen transparent
Στις Δευ 25 Σεπ 2023, 16:17 ο χρήστης Alexandros Zeppos <alexandroszeppos7@gmail.com> έγραψε:
Do you mean a separate app allowing you to change your website’s theme? Here is a detailed description of the idea.
I was referring to the website of companies that use that app for their visitors. In general.
Στις Δευ 25 Σεπ 2023, 16:33 ο χρήστης Max via Elfsight Community <notifications@elfsight.discoursemail.com> έγραψε:
@Alexandros_Zeppos Thank you!
I’ve moved your idea to the dedicated topic. We’ll keep you abreast of any changes here :slightly_smiling_face:
