Language recognition
Hi there,
I would like the AI chatbot to be able to recognize in which language the user is browsing / which language he/she selected in the webshop.
Hi there, @Michel_Holsuijsen :waving_hand:
Just a quick note: the chatbot responds in the same language as your first message. Would that suit your needs?
If it doesn’t quite fit, could you give me more details about your use case?
