Language Auto Detect
We are using the Elfsight AI Chatbot and would like to enable Language Auto Detect.
The chatbot should automatically detect the visitor’s language from their first message and always respond in that same language.
Currently, when a visitor types in English, the chatbot replies in Dutch, which is not desired.
We want the chatbot to never default to a fixed language, but instead dynamically detect and follow the visitor’s language for every response, unless the visitor explicitly asks for a translation.
Hi there and welcome to the Community, @Blog1_Website :waving_hand:
This should be the default behavior of the widget, but sometimes language detection can have hiccups due to quirks in the instructions.
I see you’ve adjusted your instructions, and now the widget is working fine:
Could you please confirm if everything is fine on your end now?
Thanks, @Max! Worked for me too. See below screenshot. Cheerio!
