A Kununu Widget would be awesome. Every Company needs Employee Reviews on their website to build trust and therefore generate applications.
Greetings @user11265
Many thanks for adding your idea to the Wishlist!
If this request gets more votes, we’ll try to consider implementation of the Kununu source to our app. We’ll keep you in the loop
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
