Is it possible to add the option to add a widget for https://www.homecare.co.uk/? I would like to aggregate reviews all in one place but you do not offer the ability to pull reviews in from Homecare.
You see, since we get a lot of requests and the process of adding new reviews sources is not easy, we have to be picky and choose the most popular requests first. If the Homecare source gets more votes, we’ll try to speed up this process ![]()
As a workaround, you can manually add the reviews from Whatclinic using the Custom Source option in our All-in-One Reviews app. Feel free to check it out:
