For senior care, it would be amazing to have nursinghomes.com as one of the options for the “All in One” reviews widget
Greetings @user11098 ![]()
Thank you for adding your idea to the Wishlist!
We’ll try to consider implementation of the Nursinghomes source in our future updates. We’ll keep you in the loop ![]()
