Add Reviews from Homestars.com
I would like to be able to import and display on the widget all my customer’s reviews left on homestars.com.
Hi @Ronen_Itzkovitch :wave:
Thank you so much for adding your idea!
If this request gets more votes, we’ll try our best to consider implementation of this source to the All-in-One Reviews app. We’ll keep you in the loop :slightly_smiling_face:
Friends, I’m happy to say that we’ve started working on this feature! :tada:
It’s currently in the Design stage, and we’ll keep you updated on the progress here :blush:
Update: the feature moved to development! :tada:
Hey everyone!
Great news - the Homestars source is now available in the widget :tada:
Find more new sources in this post - All-in-One Reviews: Enjoy 7 new sources (DoorDash, Uber Eats, Grubhub and more) 🚀
Thank you so much :clap:t3:
Ronen
A huge thank you for the feedback, @Ronen_Itzkovitch :wink:
