i am trying to create a widget but the same error keeps occuring and i have checked multiple times and i am typing it correctly. it says there are no reviews on this page but i know there are. even if you take the url itself and put it in google you are brought right to the review page
Hi there @user20896,
It sounds like you’re encountering a frustrating issue! Here are a few things you could try:
- Check the URL Format: Sometimes, even if the URL appears correct, there might be a small formatting issue (like an extra space or character) that could cause the widget to not detect reviews properly. Make sure the URL is properly formatted without any extra spaces or characters.
- Confirm Public Accessibility: Double-check that the Facebook page is publicly accessible and the reviews are not hidden or restricted in any way (e.g., privacy settings).
- Clear Cache & Refresh: It could be a caching issue. Try clearing your browser cache and refreshing the page to see if that resolves the problem.
- Test with Another URL: Try inputting a different Facebook page URL (one that you know has reviews) into the widget to see if it works with other pages. This can help isolate whether it’s an issue with the page itself or the widget.
- Contact Support: If none of these work, I’d recommend reaching out to Elfsight support for a closer look at the issue.
Let @Max and @Helga know if you need more help or further troubleshooting! ![]()
Best,
Maxim! ![]()
Hi there, @user20896 and welcome to the Community ![]()
The thing is that the links with profile.php?id won’t work in our app. Here is the correct format: Redirecting....
Please test it out and let me know if it worked ![]()
