Issue with the scroll bars
Hello… I need to remove the scroll bars that appear on the sides of each widget (Form, share buttons, etc.). Could you provide me the code (HTML / CSS) to remove them or should I do it, you?
Thanks in advance!
We’re in touch.
Best,
Patrick.
Hi @P_R_E_L :wave:
Could you please send me a direct link to the webpage where your widgets are installed?
I’ll be happy to look into this for you :slightly_smiling_face:
Hi, Max!
First of all thanks for your prompt response.
Here are links to my website where this situation occurs:
Thanks, again.
We’re in touch!
Here, another case:
Hi @P_R_E_L :wave:
Thank you for sharing the links!
I’ve checked your website and see that you are using Google Sites.
Unfortunately, there is nothing can be done in this case. Due to the peculiarities of platform, all elements of applications are being converted into iframe format, which causes scrolls appearing on your website.
I am really sorry about it :pensive:
If you have any questions left, feel free to let me know. I’ll be happy to advise!
Too bad… Really thanks for your time. I appreciate it.
Wish you all the best. Hug!
You are always welcome!
Have a great day :slightly_smiling_face:
