Trying to delete the scrollbar when using Google Reviews [WIX]
Hey all & devs,
I recently purchased a plan that includes the Google Reviews App. I have embedded this into my landing page & a scroll bar appears. I now have two scroll bars on my website and have been trying to get rid of it. I am using Wix by the way.
I have the following pasted into CSS;
.global-styles, html {
margin-top: 0 !important;
I have also attempted to get rid of the scroll bar through custom code using the article which explains embedding MPA code by way of a transparent block. Nothing seems to be working.
I would like to request assistance with this as I really dont want a refund.
my website is; www.melbournedocserving.com.au
Greetings and welcome to the Elfsight family, @Dylan_Bartolo :wave:
These scroll bars appear because of the Wix iframes. However, if you reinstall your widget avoiding iframes, they won’t appear anymore. Here is an article explaining how you can do this - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center.
If you face any difficulties with it, please request the installation of your widget through your dashboard. Our Support Team will be happy to assist :wink:
Unfortunately this isn’t working for me. Is there a way I can hire or use yourself or someone at Elfsight to optimise this for me?
Sure! Just request the installation of your widget through following the steps described in this article. Our Support Team will gladly assist you with it :slightly_smiling_face:
In the Additional Info section, do not forget to mention that you’d like to reinstall the widget avoiding iframes to remove the scrollbar:
