Issue with Ai Chatbot on Wix
Is it possible to insert a floating widget following the scrollbar on a Wix website? I’m trying, but it’s statically embedded in the place on the page where I insert the code. The same happens for the Instagram chat widget.
Hi William!
The floating widgets look static on Wix because of iframes. To fix it, you should reinstall them avoiding iframes. Here is an article explaining how you can do this - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center.
