That would be nice to integrate with Shopify so that the AI assistant has up-to-date access to products (description, status, stock availability) and to order status
Hi there and welcome to the Community, @user32157 ![]()
The widget has an option to train the assistant using the website URLs and I see you’re using it. Do I get it right that it doesn’t cover your needs?
If so, could you please explain why this feature doesn’t fit your case?
